jknappen
How would I know what differential I have? How do I know what to put in to get rid of the one wheel peel and have a little more traction etc.? I want something that is direct fit with no modification. just throw and go
Is the moe's mopar LSD the only one available. I have looked through the vendors here and haven't found anything else.
Unless you want to drop about $3000 to swap front and rear, the 3.55 is what you are stuck with. A 3.92 or 4.10 would be much better, but you cannot just swap in the higher gear ratio up front without also replacing the entire front axle.
I would just get the Mopar LSD for the rear, and stick with your 3.55 gears.
