Rear End Question...... Help!!
85Dodge360-4BBL
Boerne,Tx
1985 Dodge Ram D150
Built 360Hp
Need some help/advice. Iam going to install a sure-grip in my 1985 dodge ram D150 9 1/4 12 bolt rear axle. The 2 I have found are the dana Trac lock, and the auburn cone type sure-grip. The Dana is a spider gear style with a pin for the posi action it has clutches and is rebuild-able. The auburn also has clutches. Iam familiar with the auburn 8 3/4 sure-grips and they can be a pain to work with once they wear out they need shims to make work right. What are your thoughts suggestions??
