Rear End
Stinkymckee
Ok my rear end went out on my 01 Dodge Ram 1500 4x4 5.9L Gas.
My rear End is the Chrysler 9.25 4.10 Gear ratio.
Wondering if I can put a rear end in from a 98 Dodge Ram 1500 has the same gear ratio.
Thank you
crazykid1994
Both would be the 9.25 rear. If you can find one with a 4.10 ratio would be best. Otherwise gear swap. I don't think anything changed
Stinkymckee
Stinkymckee
Sorry forgot to put in there that mine is a 4x4 and the other one is from a 2wd
crazykid1994
I don't believe they changed anything on the 4wd models for mounting of the rear axle.
BBartow
New Port Richey, Florida
5.9L Magnum
Thank you
Only Offroad edition 1500s had 4.10s. It will be hard to find another rearend with 4.10s
Stinkymckee
Stinkymckee
I found one with the same gear ratio 4.10 but it's from a 2wd and I have a 4x4. Wondering if I can do it or not
Stinkymckee
Stinkymckee
Ok so it should work with my truck then
