Rear right turn signal
19LandSurveyor71
Arlington, Arizona
Hi guys, I have a 2018 Ram 1500 Tradesman. A few weeks ago I got a message that my rear right turn signal was out, then it went away for a few days then it came back, i checked and the bulb was out. I changed it and it started working fine again and the message went away. Today, 2 weeks later, I got the message again and the hyper flash came on and the bulb again does not flicker. I left it engine on, went to undo the housing and saw that the light was lit up, but it just doesnt flicker, So I changed bulb again, it stays on but wont flicker and message stays on dash that bulb is out. Is there a fuse i need to change? Maybe the bulb housing is defective? Any help would be awesome. Thanks guys.
14 Lonestar
It could possibly be a bad flasher relay or a ground issue.
