Rear trailer camera added
soapy
Northwest
6.4 hemi
I ordered my 2022 Power Wagon with the digital rear view mirror cargo camera. I did not realize that also included the wiring for both the rear trailer camera as well as the surround trailer camera wiring. With my RTT I blocked the cargo camera and had limited visibilty out of the rear view mirror. I ordered the rear trailer camera kit from Moparfactoryparts.com, part number 68525798AA, that includes the camera and 50 feet of optical cable. I added the camera on the back of the RTT and now have great rear visibility again. The camera has several adjustment modes, up/down and right and left so you can get a perfect picture of what is behind you. It also tilts down automatically when you are in reverse. I simply had to plug the camera in on the rear bumper and route the wires up to the camera on the RTT. DSC07659.JPG
Pudge
Alberta, Canada
2021 Power Wagon 75th
That’s pretty good. I heard the oem trailer camera has poor resolution. Is that no longer true?
soapy
soapy
Northwest
6.4 hemi
The resolution is very good IMO. I paid $572 for the whole kit from Moparfactorydirect.com My local dealer said they were on backorder and wanted $850 if it was available. I got it the next day when I ordered from Mopar and it came from a private dealer shipped direct to me. They do make a 4 camera system for surround view on a trailer which is probably the $1300 price. This was a complete plug and play unit and does offer a lot more than a single rear camera that is not motorized. I did not need to do any programming. The rear view camera automaticall defaults to the trailer camera but you can also toggle to the bed camera at any time. Have your VIN when ordering to verify that it works with your truck.
joesstripclub
Kansas City, MO
2021 2500 PW
Did you add the trailer camera connector with this kit or did your truck come with it? I've been trying to find some info to add a trailer camera but maybe I'm searching the wrong thing.
soapy
soapy
Northwest
6.4 hemi
My pickup was wired for the trailer camera from the factory with a plug in already provided at the back bumnper for both the surround camera kit as well as the single rear view camera. The camera kit I ordered is part number 68525798AA. The kit came with the camera, the mount and 50 feet of cable.
Tom Henderson
Tuscaloosa, Alabama
Cummins
Yesterday I picked my rearview camera kit up at the dealership. It is part number 68586112AA. (for a 2024 2500) As mentioned by some, you plug it in and it will automatically switch your rearview mirror and you will see what the trailer camera will see. You should have no trouble because my truck is a 2024 2500 Long Horn. These seem to be a dealer only part. I was seeing Not Available on Mopar parts websites, but my dealer got it for me in about a week. It will give a wide view until you go into reverse, then it zooms in some.
soapy
soapy
Northwest
6.4 hemi
The camera also tilts down slightly when put into reverse also. The only thing I have found is occasionally after a car wash if you get water in the plug you have to pull it apart and dry the connection. Wrap it with some good waterproof tape and problem solved.
miketx
Allen, Texas
Where did you mount it on your trailer? My trailer has a preinstalled spot on the rear top for a Furrion type camera.
Grams
2024 & 2015
6.7 Cummins & 5.7 Hemi
My ‘24 Ram 2500 LImited has the Fakra coax connector on the rear bumper….but the truck harness is NOT connected to it.
I installed the trailer camera kit 86886112AA for No Good Reason….and the Ram dealers are puzzled … seeking what “jumper harness” is missing off the truck.
Help will be appreciated.
ANGLICO
Bay Area, CA
6.4 L Hemi
If you are in a bind, do not ignore the $inexpensive wireless cameras that can run on just solar, or a simple positive / with ground, from your running lights or back up circuit.
For $40 bucks plug-N-Play.... its pretty awesome.
I bought my truck with very low miles/ used and was not able to order the option/ the harness for the extra cameras. Ended up going with a mail order $40 dollar wireless camera and small screen for the dash. This is the short-term solution until I upgrade the harness and hard wire a better system in.
The screen is more compact than it appears and fit right onto one of my Bulletpoint dash holder extensions, next to the phone.
I needed it to see behind the recovery gear/jack/fuel carrier I built.
This extends 3 feet back from the bumper (allows for full opening of tailgate) so the extra camera is a must.
soapy
soapy
Northwest
6.4 hemi
A wolf box 3 camera system is also a good option. My son put one on his Wrangler and now has front and rear camera available through the rearview mirror.
amurp15
Indiana
2016 PW
Are there ways to have the camera display on the factory screen? Been looking at adding something like this, but mounted as a front camera, and I've been hesitant because I don't want to mount another screen in my truck.
Grams
2024 & 2015
Problem Solved: Dropped the spare tire and found the un-connected harness hidden behind other harness.
Lemniscate_Mike
