Rear turn signals
Stringer
Stockdale, PA
So you can edit photos like that on Instagram? (I don't have it)
IMO
Yes. I don't use the filters they provide. I adjust the contrast, highlights, shadows, saturation, etc. until I get it to how I want it to look. Most pictures that I do on Instagram never stay on my account. When you edit the photo, it creates the edited version in your photos on your phone. Since it does this, I normally just delete the edited picture off of Instagram all together.
If I am at a computer, I usually use Ribbet.com since I can do the same edits through that website.
AustinB
AustinB
Banned
San Diego, Left Coast
Your pics almost look cartoony, like a video game or something.. Thats not just contrast and brightness is it? I've seen others post kinda the same thing before.. Looks like calendar shoots or some type of website advertising.
IMO
Stringer
Stockdale, PA
IMO
Here is an example I just did. I made minimal adjustments to the brightness, contrast, highlights, and shadows to get this.
Left if original; Right is edited
picture.php
BlownGP
Houston/Baton Rouge
He has a long list to complete lol. He is a lighting up-fitter and has been busy with a couple of projects from police cars to private vehicles such as my own lol. Personally I am running white/amber cannons the same way in my reverse lights however my amber is wired in as warning lighting. To make them you turns I would think it would be as simple as splicing the amber straight into the turn wires on each side and then put inline resistors to override the CANBUS system.
Scroll past the Firestones in my thread down to where I installed the lighting. You will see cannons on for reverse and then in the video they flash amber to give you an idea of what it would look like - http://www.ramforum.com/f41/merry_christmas_me-78298/
How bright are those Feniex LEDs? Can they be used for fog light bulbs?
Stringer
Stockdale, PA
I actually use them as my fogs when my warning mode is not activated. The are decently bright and match my 5k HIDs and Halos nicely.
picture.php
picture.php
Also, I should probably not that you will need to dremel out the existing hole, or drill a completely new hole and leave the factory bulb in place to seal the factory hole. The cannon's come with gaskets which will help seal off the hole that it goes into. In addition to the gaskets, mine also have silicone that we added around the edges just to ensure there would be no moisture.
