Rebel 2020 - LED Headlight Issue
gatorman816
Ocala
Hello. I have a 2020 Ram Rebel with LED/DLR headlights. Recently, my driver side headlights are not working properly. The DLR lights and low beam do now work, while turn signal marker, turn signal DLR, and high beams work. I disconnected battery and reconnected after a few minutes, no change.
Does anyone know what could make some parts of the headlight work and some parts not? I didn't think it could be a fuse of part of the headlight is working. The passenger headlight is perfectly normal. I am not getting any error messages for a headlight being out.
Any help would be greatly appreciated.
TNram
Nashville
I am having the same issue, did you ever get an answer?
bigdodge
Would be a good idea to pull the headlight out and unplug it. Inspect the plug for corrosion. Some of the pins might be letting moisture in and causing loss of continuity.
dakota18
