Rebel fog lights
jwheeler
Washington
I swapped the front bumper on my slt for a rebel bumper and need something to fill the fog light holes. Anyone have any input on how well the fog lights work on the rebels? A pair of factory fog lamps will cost $400. For that price I was thinking about a couple led pods on each side. Thanks for the help.
lonestar21
CA
2019 Ram 1500 Big Horn
Your truck looks really good! All you need is the black projector headlights and flares to finish the look lol
But yeah you should add the led pod fog lights instead I'm sure someone will shime in to tell you what works best
TRXHemi
Sugar Land, TX
$400?? Holy Crap!!
I'm surprised an aftermarket company doesn't have replacements for the Rebel yet.
I'm sure you can find some that work though.
Truck looks great BTW. How much did that conversion run, if you don't mind?
jwheeler
jwheeler
Washington
Yeah, I was kinda surprised someone hasn't made an upgrade kit or even a bracket to fit something different. I just picked up a pair of 3" rigid cubes. Hopefully I'll have time tomorrow to try and fit a square peg in a round hole.
jwheeler
jwheeler
Washington
Thanks! I've got the flares, just need to install them. Headlight will come eventually, found out they are not cheap.
NBrinck921
Man that looks awesome!! Was it all a direct bolt on swap? How much did it run you?? Good luck with the fogs man! :favorites13:
transam210
The fog lights in my Rebel are pretty good, although after market lights would probably be brighter.
jwheeler
jwheeler
Washington
Thanks! It would be all bolt on it you have a 2013 or newer. I think that is when they changed the grill. I had to cut off and change the lower grill mounting locations on mine.
It was about 1400 but I did the matching black rear bumper also.
jwheeler
jwheeler
Washington
Got a chance to get a little work done tonight. Installed a pair of Rigid led cubes. Trimmed out the bezel a little and made a couple small brackets. I'll get them wired up tomorrow when I install the 20" led bar below the "RAM". Didn't turn out too bad.
lonestar21
CA
It looks awesome. Good job
jwheeler
jwheeler
Washington
Finally got a little more time to work on it this week. Got the fog lights wired up. The suckers are pretty bright. Kinda wish I went with the road legal ones they make because I added a 20" bar for off-road lighting.
huntergreen
Marine Corps Navy Badge
That does look great. Was the rebel front a direct bolt on? Thanks
hankRam2015
Wow! Looks great.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Cool MOD. Just a thought, you could wire the bright fogs to your high beams and/or light bar and then install a second set of fog light pods triggered by the fog light switch that are street legal. It looks like you might have the room for it.
jwheeler
jwheeler
Washington
That's a good idea. Keep these for brights and just add another pair.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
Looks great. Is the light bar curved or straight? Got any side pics? Looking at doing a aftermarket rebel grille and would love to add another LED bar. But the one I like only comes in straight and worried about it poking out too much. Want to see how you mounted it too if possible.
DwnDak
Ontario, Canada
Looks good...
I've been wondering lately, the Rebel seems to have LED stock lighting in the fogs only. I'm wonder if anyone would know the bulb number in reference to the OE bulb number on the Sport's?? Wondering if these are canbus friendly or if the Rebel is wired differently?
jwheeler
jwheeler
Washington
It's just a straight 20". It sticks out a little but not too bad. No more than the bumper. Might be able to get it in closer if you made some different mounts but I thought it looked good and wasn't feeling that ambitious.
