I owned a 2012 Ram 1500 which had a warning label to USE ONLY HOAT coolant.
I replaced it with a 2024 Ram 2500 which specifies OAT coolant.
I subsequently bought a used 2015 Ram 1500 which specifies OAT coolant.
Since I own several other vehicles/equipment around the place that have engines using coolant….. I keep several jugs of antifreeze in the shop. A couple of the vehicles are heavy-duty diesels that require a Nitrite-additive coolant (specified to prevent cavitation on cylinder sleeves)….so I keep a few jugs of that in the “PEAK” brand.
But ordinarily, I’m a long-time / preferred user of “Prestone” ..ethylene-glycol type…almost always in “concentrated” versions.
I also own a circa-1996 Kubota M4700DT tractor (good ol’ non-emissions diesel) that specifies “ethylene glycol” but makes no distinction of OAT or HOAT….and since it’s almost 30 years old..despite the fact it has only 700 hours on it… I did a complete drain/flush/replace the coolant last summer using … you guessed it…. Prestone Yellow-Jug Ethylene-Glycol anti-freeze concentrate and distilled water mix.
Now I’m thinking this used, ten-year-old Ram 1500 likely has never had a coolant flush/change…so I thought I’d do so.
All the usual resources WARN us to NOT USE “Universal” coolants ….despite their claims because they might Still “gel” …and they do not likely have the long-term-life of standard OAT or HOAT coolants. SOOOoooo….. I’m out shopping for anti-freeze to treat the new-to-me 2015 truck to a fresh charge of coolant.
PROBLEM: NONE of the many bottles of anti-freeze found at Wally World or anywhere else Specify WHAT TYPE coolant is inside the bottle!
They ALL claim “Mixes with ANY TYPE”….or, …particularly irritating… Prestone has Five or Six DIFFERENT Formulations…in Different Color Jugs…. claiming to be for “Nissan” or “Honda” or “Jeep” or….. so on and so on….
Some of them also claim to be “correct Purple” or “ORANGE” or….whatever. (I’m anxiously awaiting a NEW RAINBOW COOLANT.)
. BUT NO DESCRIPTION on ANY of them… .. the TYPE such as OAT or HOAT.
A few mention mysterious ASTM standards …..which are undefined…..but no ISO standards are listed.
There’s a Phone Number listed for “Questions”….so I called it….which results in several minutes listening to “Our Menu has Recently Changed” …. and then making the proper selection for “Customer Service” questions….. it rolls-over to “leave a message” …or to “Press 4 for a Listing of Extensions”…which leads to me having to NAME someone…
So…. I tried “SMITH” and “WILLIAMS” and “Black” and “White” and “POISON” and “EMERGENCY”…. finally, out of frustration….“Fud-Pucker” …. none of which go anywhere except a response “None Found…. Good-Bye!” and a hang-up.
I called the number back using my cell phone “redial” feature and ended up at totally different entities such as “Federal Exchange” and such.
The point of this missive is: Despite strong warnings to Confirm the TYPE of coolant used in your vehicle…NONE of the mfr’s…not Prestone, not Peak, not SuperTech, etc etc…. provide an actual description of the TYPE of coolant in the bottle.
And the COLOR of coolants is a Well-Known Misleading clue…as there is no longer any standardization in the industry.
Damn irritating.
