Black-Ram15
I'm in need of some insight,
So I'm driving down the street and theres a detour because of repaving being done. I accidentally hit a pot hole and the CEL came on and went into limp mode right away. I pulled over really quik because i was only traveling about 30 mph and put it into park and turned it off. I waited a minuit before turning it on again, it started and drove fine but the CEL stayed on. I checked for loose conectors at the pcm and throttle body but everything seemed good. I tend to keep the engine bay somewhat clean and I haven't seen any wires that could be causing a short or something like that. Also, the ground conections are pretty clean.
I was wondering if this has happed to anyone else? Is that a sign that the throttle body is going bad?
Any info would be greatly appreciated. Thanks
