Ron howard
Ok you guys I have one for you. I have a 1995 Dodge ram 5.9 I have changed everything such as cam and crank sensor coil wires plug distributor cap now this is where it gets tricky the truck just randomly dies so I would swap relays on the asd and it will crank back up and drive for a while and then die again so I'll swap the relay with the same one I just took out and it cranks again somebody please explain that to me
