Relocate the radiator
Proride86
Vernon,bc
any one relocate the radiator on a ram 1500 or ever ran diesel radiators I want to move my rad to the center i was thinking about the diesel rads so I can use the diesel intercooler ?? Any one do this ?
HemiLonestar
Navy Badge Coast Guard
MD
The front is setup so that all the cooling apparatus fits across the front with equal access to air. First question is, why? Do you intend to get rid of the A/C condenser, trans and PS coolers as well?
P
Proride86
Vernon,bc
My trans cooler is mounted in the box of the truck and removing the Ac
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
Haven't quite done what you are asking, but installed a all aluminum BBC radiator using adapter plates. I'm still a little short in cooling IMO and will have a custom radiator built next. My radiator is like a module unit that includes the HD trans cooler, PS cooler and efan as a package. The intercooler heat exchanger is behind the front bumper with it's own efan. It cools ok under normal driving but warms up under heavy boost.
HemiLonestar
MD
Have fun with that, your truck is designed to use the AC compressor when you kick on the defroster lol...I'm willing to bet where you're located that gets use quite a bit....
So you routed your trans cooler to the bed? Why lol? You need to post a pic of that lol.
P
Proride86
Vernon,bc
Ya it’s mounted in the box with a fan on it this is drag truck bud not a fukn daily driver lol and no I don’t need ac at all haha the truck doesn’t even have a heater box any more it’s gone
P
Proride86
Vernon,bc
I wanted to use the diesel rads just cause I have a bunch of smashed trucks with good rads and they would pop right In and fit in the oem location I’m also going to run electric fans it’s a little. Big of a rad why I was wondering if any one has done it and then I can use the oem intercooler and it would fit perfectly I don’t have a battery or inner fenders under the hood so I have lots of room to run the piping
Redtruck-VA
Virginia
Pictures would be good to see. While the diesel stuff would do the job they may be a little on the heavy side for a max effort drag truck..
