Remote battery
blacked out RAM
Raleigh
Can the battery in the key/remote be replaced? I used to be able to use my remote start from over 200 yards. Now I get intermittent reaction from that distance. Closer in is not a problem so I dont think its the key/remote proper. key/Remote has just the lock/unlock and panic buttons. Thanks
B
blacked out RAM
Raleigh
Please excuse if this is a duplicate. I didnt see the original. Can the battery in the key/remote be replaced? Mine doesnt seem to have the same range anymore. 2018 Tradesman. key/remote has lock/unlock and panic buttons.
audiophile
5.7L
Yes. Remove the valet key and then use a coin or thr likes to pry the case apart.
B
blacked out RAM
Raleigh
I also had a small screw hidden by the valet key... 2035 battery if anyone wants to know...
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
When you replace the FOBs battery
Take out the Green circuit board & clean the large contact point using a pencil eraser, spin the eraser to clean, do not scrub.
Then take the part of the case that has the Panic & other buttons, look at the inside. there are little bumps that press against the contact points & sometimes they work loose from the glue
Risty2
Colorado
Cummins
Batteries Plus will help replace your key fob battery. On a side note they also have fobs for about 1/2 dealer cost and will program them.
