daveray9
- Oct 22, 2015
- 1,698
- 588
- 2020
- Hemi 5.7
How much extra oil do you need with the kit?
Nope been solid since 2015 when I put on my first truck now on my secondhi guys any one that install the filter relocating kit 5 or 6 years ago had any problems with the kits like oil leaks hoses rotting or adapters leaks any problems at all please give some info . thanks to all
Share your part list?i sorta took a cheaper easier route at first and had leaks within months.
So i bought viton oring and proper AN parts. problems gone. Hopefully no issues in the next few years.
Sorry I had to go dig up from an earlier post. I have more detail and photos on this thread post #207/page21
ENGINE SIDE:
Perma-Cool Dual Port Spin-On Oil Filter Adapter 3798
568-912V -12 Boss Viton O-ring
568-230V 2 1/2" Viton O-ring
2x RaceFlux 1/2" Male NPT to -10AN Male Flare Adapter Fitting
2x Redhorse Performance -10 45 Degree AN Push Lock Hose End - Blue
2X Gates 32925 PowerGrip Hose Clamp
REMOTE MOUNT:
Earl's Engine Oil Filter Remote Mount 2577ERL
FRAM PH2/FL-820S to PH8A/XG8A Engine Oil Filter Mount Converter Nipple
2X 2 of Aeroquip FBM1514 Size (10) Straight Socketless Hose End
3 metric screws (size 8 i think)
3 Nord-Lock Washers
HOSE:
Aeroquip FCN1006 AQP Socketless Hose 6 ft. Hose -10AN Hose
DEI Fireshield, leftover from a turbo project.
ENGINE SIDE:
REMOTE MOUNT:
3 Nord-Lock Washers
HOSE:
Isn't this the second time you've bbitched about the adapter.I'm pretty sure you whined about this a year ago.How many times are you going to repeat this story. I'm pretty sure the last time you posted this,i told you they were mass produced cast aluminium adapters,that they've been making for as long as i can remember,so they're going to have the odd one not up to par. BTW you're the only guy i know who's ever had one leak,think i also told you that once already to. If i was really bored,i'd look up your old post,but i'm not that bored tonight,lolI installed the 1127 kit on my Ram this past Saturday. Fired it up and had oil pouring onto the driveway. There is a hole in the casting of the engine block adapter. I called Hedman and they told me to contact Amazon for a replacement. They would not cover anything for all the lost oil I had to drain down before I could remove the adapter. Not to mention I had to cut the hoses because they would not pull free from the barbed fittings.
