Remote oil filter how-to
The nipple is part of the oil cooler housing. I’m going to guess the nipple there is not to long but more of a seating issue with the adapter. Either not sitting flat or the o ring. In order to pull the nipple you would have to pull the oil cooler off.
Been several years since I had my adapter off,but I thought it was just a double threaded nipple CK,that just screws into the housing.I might be wrong though,as it's been awhile since I looked,lol. Who's good at looking up parts to see if it shows as a threaded nipple,lol
crazykid1994
Now I almost want to go pull mine apart and pull that cooler off and get a nipple in there and just install an actual oil cooler behind my grill. Would probably keep the oil cooler.
Plan to add a thermostat to that oil cooler if you do.Something along either one of these wouldn't hurt to add into your engine oil cooler budget
http://www.improvedracing.com/oil-c...n-oil-filter-mount-with-thermostat-p-781.html
http://www.improvedracing.com/oil-thermostats/high-flow-engine-oil-cooler-thermostat-p-212.html
chris52010trx4
ontario
Just had a peek under my truck (16) and noticed I do NOT have that oil cooler off of the filter housing.... so i would figure my transdapt kit would work... next oil change.ill have to try it out
Sent from my SM-G965W using Tapatalk
Longhorn1500
West Sound, WA
2019 Longhorn
Cummins SO
I think I am going to do this and add an oil cooler. I like the looks of the Improved Racing stuff (www.improvedracing.com), I understand it's more expensive, but the quality looks worth it. When towing my 9,000 pound trailer, the oil temperature gets up in the 240°F or more region. I know that's not too hot for synthetic oil, but I would still like it cooler. The transmission oil temperature rarely gets above 200°F.
Chris Hoffman
New york
Got one last year and some anodized fittings and braided stainless line. Made a bracket with some stainless hardware instead of drilling and mounting directly to the frame. However, I've been lazy and haven't finished installing it.
crazykid1994
that is why I swapped to the 3/4-16 thread and I’m running a royal purpl 30-8a. This filter is huge and a lot more pleating inside for more fluid flow.
That's what I've been running on mine to,lol. Back when I bought my set-up a few years back I bought the version that uses the more common 3/4-16 thread pitch,just because it opened up a lot more filter options 5 years ago,now I think they are fairly close on filter options whether you use the 22 X 1.5 or the 3/4-16 version though. I like the fact you can find a PH-8A style filter even in the middle of nowhere,lol
Thinking I might try the Fram Ultra filters on this one,as the trucks do for an oil change/kind of why I decided if I was going to go to the dual set-up nows the time to do it,damn 5W-30 Redline up here is s'pensive so I didn't want to do the oil change,then do the dual set-up in a 100 miles,and lose one filter and the oil it holds,lol
crazykid1994
I run the fram ultra here and there. I think given how often we do oil changes one large filter is decent. Well for me. I also buy PUP through amazon. I just finished out my redline stock this oil change. Plan on going to 5w20 and 0w40 mix PUP. I do my oil change every 7500 miles anyways. Could do 10000 but i don’t trust that.
Edit: forgot to add that I can buy penzoil ultra for 23$ per 5qts on amazon with free shipping if I buy 2.
I'm more looking at the fact there should be less pressure drop across 2 filters then one. I did the first change on the wifes old 16 5.7 Challenger with PUP 5W-20 and the car wasn't really happy,it was noisier then hell actually,i only ran that change for maybe a 100 miles,then dropped the PUP out and filled it up with 5W-30 Redline,and the car was a lot quieter. I've always ran Redline in my last 2 Rams,and they both are quiet ,and when I did the cam swap on my 14 ,the cam and lifters still looked new,new enough they went into another truck with a flat cam,and last I heard that truck was still running good considering it's using my old cam and lifters,that seen 6,200 more often then not,lol
Fiddlebick
Utica ky
I got back to my leaking trans adapter kit today. This is a follow-up on my post from a couple of weeks ago. I tried to be very thorough. I've already pressure tested my 10 An braided oil lines on the bench. Made sure I got the oring seated properly on the block side adapter. Actually capped the fittings and started the engine for maybe 5 seconds, and no leak. Removed the caps, hooked up the lines and when the wife turned her over again....now it starts leaking from a pinhole in the bottom of the casting, so I'll be on the phone tomorrow with trans adapt.
crazykid1994
That sucks. Hopefully they get you taken care of.
Fiddlebick
Utica ky
Followup. I called the contact number for Trans adapt and immediately talk to a very nice man. He asked me to send a picture or short video of the oil leak, which I was happy to do. He was very apologetic and said that was a very rare failure, and in fact he was going to share that short video with his support team. He shipped out another bypass casting today, and said I should receive it in a few days. Great folks to work with! They stand behind their product.
c130badabing
Apollo Beach
awesome!! on a side note a easy way to have no mess is tin foil.. I wrap anything that might get oil on it with time foil and even wrap the little plastic oil catch In tin foil so when I am all done I just peel it off and throw it away.. and no oil mess left to deal with.. I learned this with my crotchrockets.. got tired of getting oil on the exhaust pipes.. works like a charm! Nice write up though.
I also use the tin foil method and it works like a charm!
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
has anyone used a Fram ph8a with the relocation kit? i have 2 from previous vehicles just sitting not being used.
shadowhawk
Southeast WI
I have a 4000 mile round trip planned and I'd hate to stick the wrong filter on and have issues.
alphaprojects
