Remote Start
BigDawg124
Ohio
Hello guys I have a 2017 Ram 2500 SLT so it doesn’t have remote start so I got the hood latch and wiring harness hooked it all up I used OBD JScan to program the remote start and it still doesn’t work everything is hooked up properly. Do anyone have advice? Thank you in advance!!!
diymirage
Banned
did you wire up the hood latch under the dash, pin 11 or 12 i believe
what does the evic say when you try to use the remote start?
BigDawg124
BigDawg124
Ohio
Yes it’s wired to the body control to pin 11 not getting any lights or anything when I try to remote start it.
BigDawg124
BigDawg124
Ohio
Yes it is wired to the hood latch and the body control module in pin 11
diymirage
Banned
Ok, in alfaOBD, did you set remote start to present AND hood latch to present ?
What did you so for the keyfob?
And are there any CELs on ?
Jimmy07
Did you reset the rf hub with the PIN after configuring the bcm for remote start?
BigDawg124
BigDawg124
Ohio
I didn’t use alfaOBD I used JScan from my iPhone it turned on my daytime running lights but not the remote start feature I did set the hood latch and remote start to active I didn’t do anything to the key fobs only light that is on is tire pressure light
diymirage
Banned
Did i under stood you did not use that JScan project to tell the truck it has a remote start ?
How do you try to turn the truck on, the stock keyfob or something else ?
BigDawg124
BigDawg124
Ohio
I did turn on he remote start in JScan it’s just and it says active but it’s still not working
diymirage
Banned
Do this, sit in the truck and lock it with the keyfob
Then hit the remote start button
Does a message show up in between the gauges ?
BigDawg124
BigDawg124
Ohio
I had to get a new key fob and it has the remote start button on it
Jimmy07
No I didn’t will try that
Yeah, for your 2017 you’ll need to go into adaptations > radio frequency hub settings, and read the PIN, then reset the rf hub by performing the replace procedure in order for remote start to start working. Also, don’t forget to drive above 32mph before trying remote start.
BigDawg124
BigDawg124
Ohio
Going to the truck now will text you shortly can you please send me a personal message
BigDawg124
BigDawg124
Ohio
No message in between the gauges
BigDawg124
BigDawg124
Ohio
Both of you guys are great for using your brain power to help me out thank you two very much!!!!
HarryS
Air Force
Clovis NM
How long should a RF Hub reset take? and should the key be on or off? I just tried it and after about 10 minutes, it said failed.
RamDiver
Marlborough, Ontario Canada
2021 DS
The key state is usually indicated when it matters.
AlfaOBD shows the RUN position for this activity.
I complete most changes with the Start Button in the 'OFF' position unless directed otherwise.
I have no experience resetting the RF hub and have no idea how long it takes.
HarryS
Air Force
Clovis NM
The first time it failed, the second time, it took about 60 seconds and worked.
joshhhh
