Removing and replacing fender flares on 2022 Power Wagon.
klaby
Wisconsin
I hate the OEM fender flares! But I think they are attached to the side with clips? My 15 Rebel was just double sided tape, and screws underneath. So can anyone confirm that the PW has clips and thus holes in the fender? and if so has anyone removed them and replaced with aftermarket flares, and what did you do to the holes? Seal with silicone? I do not want a water issues later.
diymirage
Banned
I can't imagine they use clips
Dollars to donuts, all the use is screws on the underside, perhaps double sided tape on the mating surface
I have a set of bushwackers for sale, but I don't know if they fit the '22
olyelr
Kewadin MI
Nope. Definitely has holes in the fender. I wouldnt worry too much about sealing so water dosnt get in there…its gonna anyway.
I agree. Dont like the ‘19 up pw flares. I would stick the ‘18 and back on there!
olyelr
Kewadin MI
Heres a pic of the newer power wagons without flares. I think they are just tabs…maybe you could just cut them off and use sticky tape like the 18’ and back have?
Xyleff
California
I was wondering the same thing. How does one go about in taking them off exactly? I sprayed in between the body and flares on the lower ends near tail pipe and rear door and it was non stop mud water gushing out for good 5 minutes. Also sprayed from inside the wheel well out and same result. Heads up for those of you who off road a lot and in muddy terrain.
Airmousam
new Hampshire
Same on my 21 PW...Thinking if I should remove them, clean behind there and reinstall...feels like rust would be inevitable if I don't something..can anyone confirm if there's double sided tape behind a 2021?...thanks!
62Blazer
Midwest
I wonder what year they started putting the holes in the fenders? On my '16 they were just held on with a few screws along the fender lip and double-sided tape.
For rust prevention, you need to clean out the inside of the fender (between the fender and inner box) and spray it with something like Krown, Fluidfilm, or Woolwax. Rust almost always starts from the inside and works it way out. Rarely the rust will start on the painted surface, unless the paint is actually rubbed off.
olyelr
Kewadin MI
‘19 and up
shanmccarthy
