Replace tail light bulbs with LEDs
chris19ram
I have a big horn without the LEDs and I wanted to replace the tail light bulbs with LEDs. Does anyone know the number for the bulbs?
Badger 13
North Idaho
2013 Dodge Ram 1500
Your book will have the bulb numbers, or should have. I would not recommend changing out to LED's. The original bulb is designed to be used with the reflectivity of the light housing itself. I know that is probably not the answer you want to hear, but I doubt if you would be happy with the results. A LED replacement for the back up lights, cargo lights, and the 3rd brake light works well and is a big improvement over the incandescent bulbs.
