Mr. Baseball
I had a timing cover leak. While apart I replaced timing chain and gears with stock version. I followed procedure and lined dot in cam gear at 6 o'clock and crank at 12 o'clock and in line with center of cam bolt hole.
When installed timing cover and damper the damper was not at tdc on timing cover, a degree or two off. Is this from torquing cam bolt, slightly moving crank? Or was I off a tooth?
How do I correct problem, if there is one. I understand distributor needs adjustment with scan tool. I am concerned about my installation even though I used a straight edge to align marks on gears. It was tight and had to struggle getting it aligned and gears on since old chain was so stretched. I appreciate experience with this. Thanks.
Edit: I wasn't planning on new chain and gears until I saw how worn they were. I rotated til originals lined up then I replaced with new set following Haynes instructions. They went on without having to rotate cam. I am surprised I didn't have to adjust cam because old chain was so loose. My tdc is 0 and I didn't check, basically replaced just how they were. Will timing be retarded? I will check it when I know more about timing. Any information will be very helpful. I was only fixing coolant leak, I'm not a mechanic, just can't afford one. Oh, I'm sure damper was off mark from tightening cam bolt and/or crankshaft bolt.
If someone could explain how timing on my '98 5.2 works that would be great. I read Haynes but not quite understanding. I hope to know before I reassemble anymore. Thanks again. Also I don't have a tensioner.
