Replacing 8.3 with original 8.4 from another truck
imwaahoo
Saline
Mi
So I put together my truck and needed a radio. Put the 8.3 I had in it until I found a suitable replacement 8.4 with nav. Tele. Sirius etc. I assume the dealer will be able to get it going with the vin # that I have. But since it's not from my truck will it loose programing? The truck it's going into is a 16 limited. The truck it came out of was a 16 limited.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Yes, dealer parts manager can pull the unlock code from Uconnect. They will need the radio serial number and your VIN (or the truck it is going to be installed in).
imwaahoo
imwaahoo
Saline
Mi
Thanks for the response!
Radio serial # should be on it, Vin from truck it came out of is available and vin of truck it's going into available. :)
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Just take a picture of the serial number and you can test the unlock code before leaving the dealer. You can also get the code online for around $15 if you don't want to go to the dealer.
imwaahoo
imwaahoo
Saline
Mi
Thanks sit, would you happen to have a contact link for the on line code?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Fatboy1989
