osprey92
- May 1, 2017
- 151
- 58
- 2017
- Hemi 5.7
I have a stock 1500 Tradesman Crew. I'm replacing the current 3" unit with an Android head unit. While at it, I've decided to replace the speakers as the upgrade is relatively inexpensive. Door units will be Infinity
PR9603IS 6x9. I've read several threads regarding the dash speakers over powering the front 6x9s if they are less than 8 ohms. If 4ohms to use resistors to balance the power. I'm undecided on the dash speakers but leaning in the 4ohm range as there is a larger selection. Question is how do you know to use a 10W 4ohm resistor vs a 5w or 20w resistor for dash speakers? What is the function of the watts - power reduction or power limiter?
