res1551cue
Reset Oil Change Warning Lights 2014 Push to Start or Key-Less Enter and Go Vehicles
If this has already been posted then please delete it.
I was helping a member out on another forum earlier and ran into an issue on how to reset Warning Lights on a 2014 with Push to Start or Key-Less enter and go vehicles. After doing a little research I found a solution.
Vehicles Equipped With Keyless Enter-N-Go™
1. Without pressing the brake pedal, press the ENGINE
START/STOP button and cycle the ignition to the
ON/ RUN position (Do not start the engine.)
2. Fully depress the accelerator pedal, slowly, three times
within 10 seconds.
3. Without pressing the brake pedal, press the ENGINE
START/STOP button once to return the ignition to the
OFF/LOCK position.
***NOTE: This comes straight out of the User Manual which is downloaded from the Ram website***
within 10 seconds.
OFF/LOCK position.
