Retro fit headlights
USA
Anyone ever retrofit these aftermarket’s with high beam and low beam led’s? I had quads, converted to hid projectors, now I wanna go led hi/low beam. I got an Alfa obd. What else is needed?35F1DE80-5A83-4D2E-A4F4-A38D88FA82D2.png
hunterdan
SE PA
2019 classic
Anyone ever retrofit these aftermarket’s with high beam and low beam led’s? I had quads, converted to hid projectors, now I wanna go led hi/low beam. I got an Alfa obd. What else is needed?View attachment 487947
Are you referring to just adding led bulbs? Or swapping the projectors to actual led projectors? Tons of guys have swapped the bulbs to led. The projector swap is harder since it's not a "standard" projector, so it'd take custom brackets to get them in there.
Check these out, they're already
LED both High and Low:
Several members on this forum have these and really like them. By the time you buy the headlights and the conversion LED projector modules it will probably cost you more.
Rp3412
