Retroshop Hid..right side flickering
Ram83
British Columbia, Canada
2014 Ram Sport
when i turn my lights on the right side flickers for about 30-40 secs
anyone have this issue?
Pigeonman
Alberta, Canada
Yup. Mine does the same thing. Flickers for a few seconds on startup and then seems fine. I saw another thread a couple days ago where JJ explained why.
blackbetty14
CT
Hemi 5.7 VVT/Etorque
If ur running the canbus adapters that's the capacitors charging up, causing the flicker. Mine do it on the passenger fog light only. I run 4 of the morimoto canbus adapters from jeremy.
Ram83
Ram83
2014 Ram Sport
yeah i got lo's and the fogs all with the canbus.just weird that only one out of the 4 flicker
blackbetty14
CT
That's basically what I just also confirmed. I think it has to be a voltage thing. Like the adapter thay flicker receives less voltage than the others.
I would put a meter on it but it's very cold and snowing so it will have to wait till the spring.
Jarhead57
Santa Barbara, Ca
2015 4x4 CC Bighorn
Same problem as you...same weather...it just has to wait:)
(S.M.R) 101
Corning, NY
2013 Sport
5.7L HEMI
Yup, My driver side fog light flickers 10 to 15 times and then sometime will not come on. I just have to keep turning them on and off and eventually it comes on and works great. Not a single problem with the other 3 lights though.
Reticle918
