Mike1022
I’m installing an aftermarket backup camera that only has 1 power wire on it located at the front with the RCA cable. I’m looking for the reverse light wire to tap into inside the cab any suggestions???
Kenwood. I’ve got it wired up now but I’m getting a weird fault now. The camera works fine and switches over when in reverse with the truck not running with keys in the ACC position. When I start the truck and shift it to reverse sometimes the camera comes on and sometimes it doesn’t
For the little I know I would start with the basic's ! Check the ground connection ! A poor ground can cause many issues, and be sure all connections are tight ! That's all I have seen posted on camera issues that I remember !Hmmm that’s strange. I know mine if I physically click the “camera” button on the unit, it will not change to the camera. It says no devices found. These things are finicky I suppose
Please Update what you do find
