Reworking the suspension and a question . . .
GIJoe2010
GIJoe2010
No sh*t, there I was . . .
Killeen, TX
Gonna run it as is and install it all tomorrow (hopefully) and report back.
GIJoe2010
GIJoe2010
Killeen, TX
Rear end is done minus new Core sway bar links.
Track bar was stupid easy to install. I removed the OEM part, used the bolts and measured by laying one on top of the other and using the bolts as a guide rod and adjusting the large nuts/ends on the Clayton kit, then install the new stuff.
It was painful drilling and tapping a hole in the DS lower control arm for the parking brake lines.
But . . . what was a pain in the **** was to torque the UCA/LCA bolts while on the ground . . . without a cheater bar. I did have a touch of axle movement on the driver’s side, but not enough a breaker bar couldn’t get the UCA/LCAs back in line.
Sequence of uninstall/reinstall of Track bar and LCA/UCA, I did them: remove old track bar then install new (to keep everything aligned as much as possible) UCA, then LCA on passenger side and then all over again in the same sequence on the driver side.
I’m gonna drive it to and from work tomorrow and check and retighten as necessary.
Yup, I still need a 3/8 -16 nut for the brake hanger.
DILLIGAF
Canada
what was a pain in the **** was to torque the UCA/LCA bolts while on the ground . . ..
1/2 Milwaukee impact on #3 setting made it easy :) .... lol....
I swear I dont even know how I would function without it anymore.
GIJoe2010
GIJoe2010
Killeen, TX
I need to find a 24mm wobble impact socket for the driver side by the fuel tank, big PITA.
DILLIGAF
Canada
I just bought a Wobble joint instead. cheaper that way... Don't buy the 20$ amazon ones...lol.. Literally sheared in half with the 1/2 impact/.... lol...
ram1500rsm
Trabuco Canyon, CA
I need to get me a damn cordless impact gun. Lol i'm still using a corded one and it ain't compact per se :)
GIJoe2010
GIJoe2010
Killeen, TX
I have all Ryobi kit, but if I were to do it all over with power tools I’d go after the Milwaukee line.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I've only used Impact for breaking bolts free. I still rely on a 1/2 torque wrench and strength to get that 180+ ftlbs. It might be time to switch it up.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Think I will check my Dewalt impact #2 & #3 settings with the torque wrench.
