I’m looking for some advice. I have a 2020 warlock, and I use it for work.
the truck has a contractor cap, and a lot of tools I carry everyday. I installed the HD helper bags that fit in the coil springs, and set them at 40psi (max 50).
My rear still sags a bit, I measure 38” to the bottom of fender liners.
Now, I’ve got 20x9 -12 Mickey Thompson’s and 35x12.5x20 bfg k02’s in the shop ready to go on.
I’m looking to raise the truck a bit on a budget.
I thought of doing bilstein 5100 in the front to raise it up 3”, and a coil spacer in the rear. however I found these tufftruck springs that say they are 50% more load capacity, and a small lift.
https://www.tuftruck.com/product/ttc-1223vt-variable-rate-heavy-duty-rear-coil-spring-kit/
Any recommendations??
