Right side rear window
Clayton Hartweg
Illinois
I have a 2012 ram Well one day it started snowing and the rear right side window would not roll back up it’ll roll down fine just wouldn’t roll up with the switch so I took off the door panel and everything checked out normal I ended up taking a 12 V car battery and hook it up to the motor to make it go back up and then disconnected the switch so it would not go down or if anyone was tempted also I removed the switch from the left side door to test the right side it would still not go up any ideas?
