hunterdan
- May 7, 2018
- 846
- 784
- Location
- SE PA
- 2019 classic
- 5.7 Hemi
Friday I had a of 2" leveling N3 coilovers from rough country installed along with a set of 1.5" rear coil spacers and had an alignment done. I've put probably 100-150 miles on it since and so far, I'm happy to say the ride is excellent. It feels similar to stock. I've had spacer lifts before on several vehicles and a set of rancho quick lift struts on my silverado. These ride the best of anything thus far. Are they bilstein's? No. But for a drop in replacement strut offering 2" of lift without the need for a spring compressor, you can't beat them. With the spacers on previous trucks, you could feel the suspension run out of droop on bigger bumps. My silverado was terrible with the Ranchos (even with corrected upper control arms). My tundra was barely any better with 2.5" front spacers. I'd not hesitate to buy these again, I'd probably even consider going with the 3" with a set of upper control arms and 2" rear spacer. Ride in the rear feels the same as factory, absolutely no detectable difference. Will the N3's hold up, hopefully. If I get 50k miles out of them, I'd consider that reasonable for a set of $330 coilovers. Initial measurements after knst showed 2.5" of lift in the front and about 1.25" in the rear. Not sure why the rear wasn't a full 1.5". Fronts were dead even on both sides, and rear was slightly lower on driver side.
Last picture was at stock height.
