Rpm’s jumping up when braking
Zgrilliot
Deleware
Just had new exhaust system put in, resonator delete with flow master super 10 muffler, notice my rpm’s have been jumping up slightly when slowing down and braking, wondering if it’s normal downshifting, or a problem.
jws123
nj
Its most likely normal downshifting you are hearing I recently put a magnaflow on my 2014 you hear the downshifts now happens with the 8 speed.
Jeepwalker
WI
2012 Reg Cab, 4x4
Are your brakes ok? I'm wondering if in the install process the brake booster check valve got damaged ...or something along the brake vacuum line. Just a thought.
Z
Zgrilliot
Deleware
Yea brakes are fine I’m still slowing down when my rpm’s are jumping up, but I should look into that, thanks!
