PDTRAD73
To all pentastar rams running 35s, have you noticed much power loss since upgraded from stock tires/wheels? I know that fuel economy will take a hit, more concerned about losing power. Thanks
Their seems to be a huge language barrier with some people. You won't lose any power, you'll lose the illusion of " power ". When you tow a boat, you're not losing power, and that's essentially what you're doing here, towing a very small boat.
The rotation of the tires will effectively change your gear ratio, so you're going to , again, have the illusion of power being taken from you. In reality, with the 8 speed, you're not. you're going to have a drop in MPG, and you're truck will feel sluggish off the line, but that's not because you've lost power, it's because you changed your gear ratio and made it smaller than it already was.
think of it this way. you are on a 10 speed bike, and you start pedaling in 1st gear. one rotation of your feet equals a quarter rotation of the tire. however; once you get it up to the 10th speed, half a rotation of your feet equals a full tire spin. you are not gaining more power as you move your feet (unless you deliberately push harder / faster ). Say you were a robot and it was just one speed of foot movement. Either way, same thing is happening here, only you're going down instead of up. Luckily for you, it'll be minimal. I'd obviously advise against it merely for the fact you have a v6 and it's already under powered for a truck, no reason to go adding 160 pounds of rubber to the axles!
I have a leveled pentastar. I’m going with 305/55/20 nitto g2. They measure 33.25” and 12.45” wide. They only weigh 49lbs. I actually prefer the 33” tire look, and I won’t be losing the “power loss” to a gear ratio change from going up in size.
I mean no disrespect but 35's is a definite power loss whether one wants to call it an illusion or reality.
But I do agree your effective gear ratio will change, performance will suffer and mpg will drop.
To the OP we would doing you an injustice if we didn't share the reality of bigger tires. I was discouraged at the loss of performance but changing the rear gear ratio will fix that.
None taken. Everyone has their opinions, mine just happens to be factual. It is an illusion, their is no actual power loss. The truck still makes 295 Horsepower whether you have 100 pound tires, or 300 pound tires. The rotational force used to move them does nothing more than lower your gear ration. Realistically, not even by that much.
Why do you gotta get all technical and stuff? Lol just kidding brotgerNone taken. Everyone has their opinions, mine just happens to be factual. It is an illusion, their is no actual power loss. The truck still makes 295 Horsepower whether you have 100 pound tires, or 300 pound tires. The rotational force used to move them does nothing more than lower your gear ration. Realistically, not even by that much.
3.21s unfortunately. I’m hearing it’s not horrible w the 8 speed trans thought.Exactly, hp on the motor has not changed but hp to the ground has. Fact
So what gears does your V6 8sp have in it.
