Rust repair
adamh3844
Harrisburg, PA
4.7l
37668EE5-2057-4D77-BCFA-902ADA44F316.jpeg Have a 2002 Ram 1500 SLT QC with 87k miles. Great condition except small bubble rust coming from passenger rear wheel well. Looked like this when I took it off after removing some of the really bad rust B240D3D3-3BBD-474A-B55C-254DF104EE8D.png
After removing as much rust as possible I layered on some anti rust (3 coats) then sanded and add 3 coats of primer and 4 coats of glass clear coat. In lighting can see the clear coat doesn’t blend completely natural first time doing this. Then added bolt style fender flares 641313F7-37AF-45C9-8D37-917BC8CA3324.jpeg
Finished product. Yeah
hdvespa
Southwestern PA
Who's fender flares did you install? Whats the model and where did you get them. I have the same issue with my 2002 RAM1500
adamh3844
adamh3844
Harrisburg, PA
4.7l
https://www.ebay.com/itm/Rugged-Textured-2002-2008-Ram-1500-2003-2009-Ram-2500-3500-Pocket-Fender-Flares/382299141700?fits=Year:2002|Model:Ram+1500&hash=item5902cdf644:g:cD4AAOSwf7Ja69hd
There are a few different kind. After purchase I realized the bolts were just for show and I wanted to create a tight seal to prevent water running down under the flares so went out and bolt Self tapers. These are rugged texture there are a few different kinds.
I just matched the self tapers with bolts for front to give similar look and this way if I need to replace the bed due to rust I didn't ruin the front with self taping holes.
