Scan tool that won’t break the bank
Okie345
Na
If you have an android, you can get an elm327 Bluetooth obd adaptor for 11 dollars, forscan ford specific for 5.99, torque pro I think was 8, I should be getting alfaobd soon for 50. Which should cover pretty much everything for ford Chevy and dodge.
Justthebutler
BC
2017 Ram 1500 SLT
I prefer the direct USB OBDLink EX for my Ram, But I use one almost identical to THIS for my other vehicles. However Alfa is the only option I know that can cycle the ABS
kmsbryans2018
OBDLink MX+, Android phone/tablet, AlfaOBD
Any setup that will support 2nd Gen Rams?
AlfaOBD's website states Dodge 2005-2021... my truck is a 2000.
Also, can a 3.9L V6 ECU be flashed to run a 5.9L? The last time I asked 10+ years ago the answer was no. Wondering if that's ever changed.
danielmid
Southeast WI
2015 Sport 4x4
No idea really, probably best to search around in the 2nd gen forums here:
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
No. A V6 ECU has 6 injector drivers. To run a 5.9 it needs 8.
To add, just for example you can see this is for a V8. Notice it's a universal board so it had the capability upto V10.
You need to just find a 5.9 V8 ECU.
Tom Davis
Navy Badge
Colonial Beach, VA
5.7L
I use the MOTOPOWER MP69033, $25 on Amazon. Does everything I need, and seems to work fine.
ram86
arkansas
5.9 la
Just a heads up for you guys and to make the $200.00 sound like a great price. My scanner is a Snap On Triton D8, cost is over $8,000.00 plus $1,500.00 a year for updates. Also I learned on the last update starting in 2017 for dodge and others coming soon you'll have to pay $50.00 a year to a place for any scanner to work on it and others that start using it.
PaleFlyer
Charlotte NC
Or buy the $55 KAOdTech bypass cable once, and just stick it in under the knee board of any 2018+ Chrysler...
PaleFlyer
Charlotte NC
Hell, that looks like it's just a couple transistors, and some conformal coating... That's an easy solder job!
KrazyBiRde
Corona, CA
Etorrque Hemi 5.7L
I use a tool I bought off Amazon called a "ELM 327 Mini" and any smartphone app. I've used Torgue - AlfaOBD - Auto Doctor and CarSys
Can you post a link, seems that some of the ELM 327 have quality control issues. Some do not work.
Thanks, much appreciated
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
DutchRamRepair
Netherlands
CDA6 will work with Chinese witech interface.
Remote installed. No extra costs to run.
If you want to view measuring values. This is your best option.
( i use it, with sgw bypass cable )
I do prefer Alfaobd, for now, on a laptop.
Soon on android. Might work te same.
MrOctNot
Oh so many scan tools to choose from. You can request lists of available functions for specific vehicles to help make your choice.
I've ended up with Autel MaxiAP AP200 and also JScan software using iCar Pro VGate plug-in.
I own a 2008 Town & Country Limited and a 2005 RAM 1500.
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Check out INNOVA model 7111 $549 at ORielly's. lot of info on it on you tube.
BenchTest
Midwest
Looking to see what the current thoughts are on "budget" scan tool for 2024 (almost 2025) that allows ABS bleeding/manipulation of various components for service. Also to clarify, 2018+ vehicles will need a gateway bypass cable, correct? Thanks.
