So I had HBS 2.5" leveling spacers on my truck for about 6000 miles. I wanted to go with Bilsteins right away but they were OOS so I went with the HBS spacers for the time being. Bad move.
I was one of the naysayers about the suspension angles being HORRID (I figured they were a little off, but this was bad). Needless to say I tore the lower control arm ball joint boot. I can say without a doubt that that I would NEVER recommend the cheap route of a coil spacer. I will get pics up later today of the spacer + factory coil and the Rancho QLL system side by side.
The Rancho QLL was MUCH easier to get in as well. Did not have to stress the CV axles like I did to get in the spacer and factory strut in.
Now, onto the Hell Bent Steel spacer. I am going to be in contact with them. I pulled out the strut and the spacer was bent!!! One side was just slightly out of wack but the other was WAY bent. It was HORRIBLE! I had a helluva time removing the strut due to this. I was always under the impression that HBS provided a quality component but I guess I was wrong. I will also have pictures up later this evening of the spacer that is bent and both of the factory struts w/ spacers side by side.
Pics added below. Factory strut w/ spacer next to the Rancho. Also pics of the HBS spacer and how it bent.
Running static CV angles outside of design spec, bad steering rack angles, incorrect sway bar link lengths, etc. All parts killers over time... But the damn trucks look so much better leveled!
