SEALING 3RD BRAKE OPTIONS
Discussion in 'Exterior' started by ramportin1, Mar 16, 2018.
Sponsored By: BAK Factory Outlet
  1. ramportin1
    ramportin1 Sickest member here
    32
    3,186
    1,988
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    BEFORE SOMEONE HITS ME WITH "SEARCH FUNCTION" lol I already have went through the many many threads and every one is for 4th gen 3rds and the back housing is different. I already bought that boat rubber gasket the one guy used and tried but it wont fit a 3rd gen its much to thick.
    Im not a fan of silicone'n it or using gasket maker because if a bulb goes i dont wanna deal with that.
    So does anyone know of a better option? Or maybe if that new 2018 or whatever gasket they finally switched to will work on a 3rd gen back? or maybe a better aftermarket one?
  2. Nick@GotExhaust
    [email protected] Senior Member Preferred Vendor
    36
    3,531
    2,512
    Aug 1, 2017
    NY
    Ram Year:
    Engine:
    I dont have a great option for you BUT the 1st Gen Raptors had an issue with the 3rd brake light leaking. I never had the issue but when I put LED's in there I figured I should do something to prevent it. When I had mine I actually used a left over electrical junction box gasket that I had and cut that to fit. It is a very thick but pliable gasket. It may not be the best option or easiest but it did work.
    Did you use the SEARCH FUNCTION :crazy:
    ramportin1 likes this.
  3. ramportin1
    32
    3,186
    1,988
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    Thank man. If no-one has a great easy fix I will look at going this route and making one seems like it being such a famous issue someone out there woulda made a better direct replacement but I haven't been able to find one
  4. Nick@GotExhaust
    36
    3,531
    2,512
    Aug 1, 2017
    NY
    Ram Year:
    Engine:
    Invent one have us be your authorized dealer!
    Justin_Hart and ramportin1 like this.
  5. Lil_Ram
    Lil_Ram Senior Member
    1,301
    653
    Apr 10, 2015
    Ram Year:
    2003
    Engine:
    Power tech 3.7L
    What about a make your own sheet gasket thing. Most part stores sell the sheet cut it to fit then you have a gasket and no garbage later
  6. mondo
    mondo Senior Member
    954
    480
    Aug 4, 2014
    Columbia, Pa
    Ram Year:
    2014 2wd express rcsb
    Engine:
    Wonder if sink drain putty would work??
  7. ramportin1
    32
    3,186
    1,988
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    Now that's a unique idea, I bet you could use some kind of putty like that and work well
  8. ramportin1
    32
    3,186
    1,988
    Jun 28, 2017
    Oregon
    Ram Year:
    Engine:
    Think I'm just gunna find some kind of nice gasket material and cut my own, thanks for the responses guys!
    mondo likes this.
  9. RamCreeper
    RamCreeper Senior Member
    157
    33
    Mar 20, 2018
    St Augustine, FL
    Ram Year:
    2005
    Engine:
    4.7L V8
    I had a problem with the Brake light leaking on another truck. I took wax paper and taped it around the brake light then filled it with clear silicone and wiped of the excess. Let it dry for a few days and it sealed up perfectly. I haven't taken a look at my Dodge to see if I could do this yet but it worked great on the old truck.
  10. xtremewlr
    xtremewlr Senior Member
    804
    334
    Feb 12, 2015
    Tucson, AZ
    Ram Year:
    Engine:
    Ingenious idea, thanks!
Share This Page
