Seeking Hemi 5.7l Tick mechanic in Alaska
ArcticHemiClub
Alaska
5.7l Hemi
Hello, I am looking for a good mechanic who can help me fix my 5.7l engine in South Central Alaska. Any suggestions? Thanks!
Details:
Hemi tick cold, get better when warm,;
Truck has idled a lot in its previous life on Slope;
Code on #5:
PO305 cylinder misfire
Mechanic changed the plugs and coil (but not the wires);
I use Redline 5w30 with good quality filter for the last oil change, seems to like it!
i use seafoam for fuel injectors, but no change.
150k miles
Burla
2010 Hemi Reg Cab 4x4
It is probable the cam/lifters are dead, time to replace. It is very likely you cam lob 5 is worn to the nub, be prepared if you keep pushing it that it might leave you stranded. I wouldnt wander to far into that bush brother, till this is fixed. Get 2016 lifters, they have better needle bearings. Take a picture of cam and lifters to find what failed. Was the damage smooth or pitted?
Details:
Code on #5:
150k miles
You could see if Brandon W might take it on,or know somebody up in that area,as he's in Northern BC
Mrbyh20
Wasilla, Alaska
Sorry didn’t notice how old the original post was.
