Serpentine belt unusual wear
Jtblackram
Long Island
2018 Ram 1500, 5.7 hemi qc. 20,*** miles.
Serpentine belt seems to be showing an odd wavy pattern, as well as some unusual wear. Im no expert, but I don’t think a serpentine belt should look like that. Not to mention i have an intermittent squeak at idle
Jtblackram
Jtblackram
Long Island
here are the pictures
Is this a normal wear pattern? I wouldnt think so
Tach_tech
5.7L HEMI
From the picture it looks pretty normal, but you are only showing 1 side of the belt.
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
If you decide to replace it, I recommend keeping the original belt in the truck just in case the new one breaks down the road. The old one will at least get you to the parts store. Or you could just buy 2 new ones so you have a spare, but I like saving money. Of course, you'll need to keep a socket and breaker bar in the truck to install it on the side of the road.
bm02tj
B C Canada
Keep the old one and if need be some one will have tools but not many with the correct belt
Brandon-w
Yukon
2015 Ram 1500
I'd stay away from The gator backs. They create alot of static electricity. Enough so gm put out a tsb for it creating static and taking out the transmission controller. Just a heads up.
chri5k
USA
Diesel
I haven't seen the back side of a serpentine look like that. It seems the rubber on the back side is worn off exposing the cloth material underneath. The seam where the ends are joined is usually hidden by the rubber coating. I would check for binding on any accessory that has a pulley touching the back side of the belt. Looks like something is wearing the back side at an unusual rate. Also, check the belt tensioner to make sure it is up to snuff. Some of them have a pointer and scale. The manufacturer publishes a torque spec to move the pointer to a point on the scale.
+1 for the Gates Green back belts.
Tach_tech
5.7L HEMI
Here is a picture of a brand new mopar belt for a 5.7. The seam is visible on a new belt. So I still don’t think anything looks wrong with that side of the belt that you’ve shown.
Jtblackram
Jtblackram
Long Island
Hard to tell from the pic. if the other side doesn't have cracks in it you should be good. But when in doubt change it not worth breaking down
ok thanks, i wasnt sure if it was a seam or not because of how it was angled, looked funny to me. Ill keep an eye on it
Blazerman
Germany / Hamburg
Hello together,
i will change my belt, rolls, etc. too.
There are two Mopar belts at rockauto?
Which one is the right one for me?
Or can i choose a other manufactor?
Same question for the rolls, etc. are ACDELCO Parts good enough?
Best greetings from Germany
RodeoRam
North Carolina
Hemi 5.7 2500 CC
Hello together,
Rockauto is not very descriptive on the two Mopar belts. Usually, there are two lengths of belts depending on whether the vehicle has air conditioning or not, but Rockauto does not mention anything about A/C. HD trucks could have a second alternator, too, making for a third, longer belt. I suggest you study up on it more and not just trust the Rockauto site. Check other auto parts sites to see if they are more descriptive and compare part numbers.
From my own research on those two Mopar part numbers, the Mopar sites say that 5192067AC has been discontinued, and only 4593852AB is for your 2011 5.7L.
I've always bought Gates belts just because my dad did, and they've never let either of us down. Just like Mopar parts, you'll pay for the brand name with ACDelco. It's almost twice the price of the Gates, and I would doubt it's any better quality.
Blazerman
Germany / Hamburg
Hello RodeoRam,
many thanks for your great answer. Your informations are very helpful for me and so i can order the right parts and save money.
Great support, many greetings from Germany
Blazerman
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Hello RodeoRam,
Blazerman
Look up your parts online like Mopargiant..........then copy & paste part numbers on the rockauto.........makes it easier........get the GatesHD belt toward the bottom for the best.
Dodge 1500 4X4
Rochester, NY
I vote Gates HD to me they are the best belt on the market made in the colorful state of Colorado!!!
RodeoRam
North Carolina
Hemi 5.7 2500 CC
Yep, I used to drive by the factory in south Denver on my way to Colorado Springs for my reserve duty.
