Service 4wd light is on
I'm getting a service 4qd light on and my will not engage
  • What could be causing this
    Votes: 0 0.0%
  • Differential
    Votes: 0 0.0%
  • Total voters
Ram4529
Cheyenne
I recently started my truck and noticed that I have a service 4wd light on my dash I have a floor shifter and my 4wd will not engage it makes no sound like it attempts to lock in.
Brandon-w
Yukon
2015 Ram 1500
You have the stick shift on the floor? That should be a direct mesh no electronics interfering. Sounds like it's a front axle actuator or wiring to the front axle actuator maybe? Got a code reader?
RamCares
n/a
n/a
Hi Ram4529,
I regret to hear of the trouble you are experiencing with your truck. I know that you are reaching out to fellow forum members on this, however, please know that if you end up working with your dealer our team is just a PM away and we are more than happy to provide you with an additional layer of support for that process.
Mark
RamCares
R
Ram4529
Cheyenne
R
Ram4529
Cheyenne
I dont have a code reader I took it down to get it read and they said no coded came up. They also said that it really doesn't read 4wd codes .so I'm not sure , with no electronics could this be an easy fix?
R
Ram4529
Cheyenne
Brandon-w
Yukon
2015 Ram 1500
What year is it? I'll see if I can find some wiring info
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
When my truck was out of alignment after installing my lift, I got that as well. I guess if your front end is out of whack, that could also be it.
