Shark fin antenna swap???
Discussion in 'Wanted' started by BEAST19, Jun 8, 2017.
  1. likes2build
    likes2build Senior Member Supporting Member
    437
    274
    Jun 12, 2018
    Yuma & Kingman AZ / Albany NY
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    About 1 hour and there is nothing hard about at all, it's just swapping 2 cables and the base. Sorry for the typo 68148258AD
    circuitguy likes this.
  2. circuitguy
    circuitguy Senior Member Supporting Member
    649
    475
    Aug 10, 2018
    Elk Grove, CA
    Ram Year:
    2017 Ram Tradesman Regular Cab
    Engine:
    5.7L HEMI
    Thank you!
    So one cable goes from the antenna half way to the radio and the other cable goes from the radio half way to the antenna? The two connect in the middle? These are correct for my Regular Cab Truck? Also this runs down the drivers "a" pillar or the passenger one?
  3. likes2build
    437
    274
    Jun 12, 2018
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    One cable runs from the new antenna base along the roof header and down the right (passenger) A pillar and stops in a blue double pin connector just above the dash. The other cable runs inside the dash from the blue connector in the A pillar termination to the back of UAS / UAQ radio.
    I can't tell you if this is correct for your 2017 because of the year difference and not knowing what radio you have or what you're trying to accomplish with the swap. It worked for my 2018 RC with a UAQ radio and I did it by searching ebay and TrueCar for a 2018 RC with a 8.4 NAV radio and a shark fin antenna. I gave Benny @AllMoparParts.com that trucks VIN and he did all the work and nailed it!
    ps2012st and circuitguy like this.
  4. circuitguy
    649
    475
    Aug 10, 2018
    Elk Grove, CA
    Ram Year:
    Engine:
    5.7L HEMI
    Thank you very much for the info. Will be doing mine soon.
    likes2build likes this.
  5. likes2build
    437
    274
    Jun 12, 2018
    Ram Year:
    2018 Express RCSB
    Engine:
    3.6 Pentastar
    Your are welcome! It was @kad that turned me on to searching out ebay for a perfectly equipped truck for a donor vin to get the right parts every time.
    ps2012st and kad like this.
  6. circuitguy
    649
    475
    Aug 10, 2018
    Elk Grove, CA
    Ram Year:
    Engine:
    5.7L HEMI
    That's what I have been doing for the last two years. I have a vin from a new 2018 Ram Sport Regular Cab that I have been using. Did my complete interior with this vin guess I forgot to get that one extra cable.
    ps2012st likes this.
  7. MidTennMtneer
    MidTennMtneer Junior Member
    38
    21
    16
    Jan 19, 2019
    Princeton, WV
    Ram Year:
    Engine:
    Pentastar
    Sorry to bring up at old thread, but this is about the only one I found in search. From what I've seen by Googling the sharkfin there are two cables coming from it. One purple, one mustard. I have a '17 CC with 8.4 w/ NAV. I am not subscribed to Uconnect Access.
    I have an add-on portable XM radio that I installed. I thought I'd be smart and just unplug the antenna from the back of the 8.4 and plug it in to my portable. Save running a new cable. Works like a charm, however, now my NAV doesn't work. I discovered then (and reading through this topic) that the mustard plug is for XM and GPS. I assumed the purple plug was the GPS wire.
    So, am I going to have to run the wire for a new XM antenna or does a vendor make a fakra plug splitter? Will the signal be strong enough if I split it? Do I keep the sharkfin or go a different route?
    Not trying to threadjack. It is somewhat related. haha.
    Thanks!
  8. Mpgrimm2
    Mpgrimm2 Senior Member Supporting Member
    3,254
    1,837
    Mar 30, 2014
    Anderson, SC
    Ram Year:
    2018 Laramie Crew
    Engine:
    5.7L
    Send me a pm with your phone number.
    (I tried this with my last ram)
    M² Mods.
Share This Page
