Short in steering wheel
Audiowriter
Indiana
The "lights" on the buttons on both the Cruise pad on the right and the dash Control pad on the left - go "OFF" when I turn the wheel to 2 O'clock. Then back on at 3 O'clock as the wheel continues around. This does the same in the reverse direction. (The lights basically "flash" off at 2 O'clock.)
Could this be a problem with the continuous slip connection in the clock ring?
Fuel35 67
Hanford
Probably the clock spring. You’ll need to pull the steering wheel to see what’s actually happening. Could be just a dead spot. Disconnect the batteries before hand, don’t want the air bag to accidentally inflate.
