Side mirror light removal
_simm_ns
Arlington, Texas
Anyone know how or if it's possible to unholy the light assembly from mirror housing???,
_simm_ns
_simm_ns
Arlington, Texas
Hahaha damnit. Unmount** trying to take the fixture out of the mirror housing.
firebuff17
Ct
Which mirror do you have?
Tow? Standard? Sport?
stimpy433
IOWA
I found this if you are talking about the puddle lights... hope it helps!!!
Start by operating the mirror to the fully down position.
- Grasp the top edge of the mirror, and pull it further then the adjuster did...this will release the top clips.
- Look down inside to see the lower hinge style clips...separate them and remove the mirror glass.
- Disconnect the heated mirror wires (if applicable)
- Locate and remove the 3 screws that hold on the mirror cover.
- Remove cover
- Locate latch tab for LED lighting unit and release
- Gently pry the LED unit from the housing.
- This might take some persistence, and the weather seal sometimes hangs on to the unit and resists it's removal.
_simm_ns
_simm_ns
Arlington, Texas
- Remove cover
Awesome! Thanks man!!
