Silence...
KG5TUD
Northwest Arkansas
This happened in my 2019 All New Ram 1500, no audio at all no radio, no navigation audio, no bluetooth connection audio, this lasted over an hour then at a dealership just started working. BTW there was no error code either.
RamCares
n/a
n/a
Hi KG5TUD,
We're sorry to hear about this! Please let us know if this happens again and we'll have this documented and escalated for further handling.
Lydia
Ram Social Care Specialist
KG5TUD
KG5TUD
Northwest Arkansas
Hi KG5TUD,
Lydia
One other thing, where under the hood can I get a switched 12v power point to use for a relay trigger. All I can find are 12v on all the time.
RamCares
n/a
n/a
Hi KGSTUD,
Unfortunately, as we are not mechanically trained, I am unable to determine where to get a switched 12v power point. We recommend contacting your dealer as they will have the appropriate resources to answer your question.
Lydia
brian42
San Diego, CA
2019 5th Gen (Sold)
HEMI 5.7L
I had the same issue. Went 2 days with no sound so the dealership could (not) hear it. Took the service writer out to the truck, turned it on, and the audio worked. Seriously?!?
I have only had it happen twice since then and, even though there's no dealer fix, there is a workaround. The next time it happens press the input button on the back of the right side of the steering wheel. One click and your audio should be back. Don't ask me why that works but I read about it and it has worked for me the few times my audio stopped for no reason.
Someday I'll get it to happen when I'm at the dealership but at least there's an easy out without turning off the truck or disconnecting the battery.
1st Time Ram
MN
I also have had this issue with my 2019 Ram (6 times so far), I've had it to the dealer twice, they did a flash update to the radio, it did the same thing the very next day. I read on this forum about toggling the mode, worked like a champ! It appears this is a fairly common issue, I would hope that Ram will come out with a permanent fix.
joshhhh
