I have actually found the single exhaust to be a little louder than those that have the single in/dual out mufflers. The 18" Magnaflow is my favorite all around muffler for sound and performance.
Anything else far as other performance parts or what? The magnaflows have great sound.
We can hook you up with just about anything performance wise. Anything done to the truck currently or is it still 100% stock?
Tuner, gears, intake are gonna make the truck a whole new toy
Superchips Flashpaq 03-09 Dodge Ram Gas Trucks
Motive 4.56 ration Front ring and pinion gear set for Dodge Ram 4x4s. This is for the 8.0" front differential.
Motive 4.56 Gears for 9.25" Rear
For intake we just need to lable it as a 4.7 motor and get you going.
The first thing is a Superchips tuner that will allow you to tune your truck. Very user friendly and will get you a few more HP. The Motive 4.56 are new gears for the truck which will make it pull harder from a stop. The Superchips you can install, the gears are better left to a shop with experiance because it is very time consuming and requires being set corretly.
