Snow plow
Pruppert04
Illinois
This might be a stupid question. But I have a 2007 Dodge Ram 1500 automatic with the 5.7 hemi. Is this truck equipped for a snow plow? Is there a specific “package” that would’ve come from the dealer? Or can I just buy a snow plow and throw it on and I’m good to go? Thanks in advance
Recoil
By "equipped", do you mean did it have some sort of "snow plow package"? If that's what you are asking, the answer is no. You could beef up the front suspension yourself and then get a plow kit that is made for your truck. I hope that helps.
P
Pruppert04
Illinois
Thanks! Last year I rebuilt the front end. I used mostly aftermarket moog suspension parts. I put on moog st8603 as my struts. Wouldn’t happen to know if that’s good enough? Thanks again
Recoil
It will all depend on the weight of your plow setup. The more weight, the more you need to beef up the front suspension.
Decide on what plow package you are going to get first and that should help you determine if your suspension parts are enough to keep it from sagging too much. If you plan on getting a quick connect/disconnect plow (which I highly recommend), then only put the plow on when you are plowing (or the night before a storm if you are informed) and just keep the plow mounting kit on all the truck at all times with the plow removed when your not going to use it. Removing the plow in between uses is the best way to go as it will save on your front end when driving. If you plan on removing the plow between snow storms, then your current front end components should work just fine.
