Status
Not open for further replies.
Gixxer750
N. Idaho
2015_2017
SOLD. - SOLD. - SOLD - SOLD - SOLD - SOLD
Driver door Master window switch bank. - never installed-
W/ power folding mirrors, power mirrors, including tow, front auto up/down switches, window lock out and vehicle lock/unlock....is a 2 connector 3+9 pin. Fits 2013-2015 1500,2500,3500 part 68212784AB.
Clustet dust cover SOLD
Switch bank SOLD
StoneDude76
West Chester,PA
Bump for Gixxer750. Received the Quick Lift struts arrived today. Look good. Now I have to find time to put them on. To all the members this is a good guy to buy from.
Sent from my VS988 using Tapatalk
Gixxer750
Gixxer750
N. Idaho
2015_2017
Word of advice for breaking loose the lower ball joint for the knuckle. There is a flat spot that looks cross hatched, remove all nuts but the upper control arm, remove all other linkage , sway bar arms, axle, etc, then take a 2lb sledge if not full size and beat that flat spot on the lower control arm like it owes you money. Torque for hub nut is 280 ft/lbs + something like 270° if i remember correctly. It was difficult to find at the time. And all other ball joints just slam with the ¹/2" airgun to tight, not ridiculous. And use thread lock as the oem original nylon lock nuts are not reliable when reused (mprobanly a myth). Took me 2hrs for the first and an 1hr for the 2nd. With a nap in between cause it was hot as He**. Enjoy. If you decide to ramp up your tow capacity with those HD coil bags let me know and maybe a we can work out the compressor and remote unit
Armkb
Stormville New York
Master switch still available? Title says it fits a 2016 but in post you say up to 2015. I have a 2016 and am looking to install power folding mirrors.
Gixxer750
Gixxer750
N. Idaho
2015_2017
Easy check is to pop yours up and see if there is one or 2 connectors. If you have 2 this is your switch. It was one of those mid year changes on some models...
Sdpadrez
This is not exactly correct. If you have manual mirrors. The power folding will not work. You can enable options like puddle lights, turn signals(if the mirrors are equipped with them) and it will work. But you need an updated module for power folding to work
Gixxer750
Gixxer750
N. Idaho
2015_2017
Yes, I am only supplying the button. A switch is just a switch. The wiring and pinouts at the module and mirror are up to the buyer. However. The 6 3 pin config works for non power fold also. Memory mirrors i can not speak to.
Gixxer750
Gixxer750
N. Idaho
2015_2017
So you are correct the module determines what will be preformed via you specific module and pin out. But i bought after market power fold tow mirrors that worked exactly as they should with this. Just had to rig 2 pins and some wiring
DERJ
Austin
2014 R/T
I’ll take the door switch...
Status
