Dogeexpress
- Joined
- Jul 31, 2015
- Posts
- 20
- Reaction score
- 4
- Ram Year
- 2015
- Engine
- Hemi 5.7
Ive searched for about a good 45 mins now and can't seem to find any. So any suggestions?
There is no need for solid mounts on these trucks until someone can find the breaking point of the oem ones.
I use to run a setup like this. Keeps your engine still but allows you to keep your rubber mounts.
I did the same thing on a old 67 mustang I had that had the hp turned up just a little. This was before solid mounts were made for them and I would snap stock mounts and bolts that heled the chain. Finally made a heim mount that connected to the motor in 1 spot and frame in 2
I have found the breaking point I have tried all oem mounts none hold upThere is no need for solid mounts on these trucks until someone can find the breaking point of the oem ones.
Wheel horsepower or crank? Big motor?nitrous? Forced induction?750 plus horsepower
It picks the front wheels up off the
ground when taken off with hot tires
I run really still mounts in my Evo.
Trust me. Dont do it... you brain will thank you.
I know the Evo is a 4 banger. But it vibrates the entire car. You feel it in the seat going from the crack of your ass to an eventual crack in your head.
They're terrible unless you are full blown race mode
