Spacer brand with SRT-10 wheels
012RAMbo
West Monroe, La
Hey guys. I just ordered a set of gloss black SRT-10 reps with 305/45r22 Nitto 420 tires. I have read that some guys have issues with rubbing and some don't. To the guys running 1/4'' spacers, which brand are you using? I see some that are pretty cheap on ebay, like $24 for all 4. And I know a bunch of the lifted guys run the Rough Country 1/4'' spacers with their larger tires. Which ones are you using and any vibration or other issues? Thanks.
012RAMbo
012RAMbo
West Monroe, La
Thanks for the response. From what I have seen from a couple days of looking, seems like they tend to rub more on the 09-12 models. I have seen several 13-14 model guys say they have no rubbing with that setup, even though it is still pretty close. I found some 1/4'' spacers at the local Autozone and Oreilly parts stores. I will just bolt them up and if I need spacers, they should be pretty easy to get a hold of quickly.
012RAMbo
012RAMbo
West Monroe, La
BrBlack, different offset from what? Year models, or stock wheels?
They are 20x10 +25.4mm offset. All srt wheels I have seen have the same width and offset, unless they are 20''. Those come in 9" width and shouldn't have any rubbing issues at all.
UNBROKEN
2012 Ram R/T
Check your front sway bar...I bet they have rubbed you just never noticed it.
A little tire rub on the sway bar is a non issue so it's really irrelevant.
SIhemi
Pennslvanvia
I have the srt 22" with 305/45 nitto 420's. I was rubbing the upper control arm. I picked up a set of 1/4 spacers at pep boys. I haven't had any problems yet. My truck is an 09.
InspectGWS
Houston, TX
2014 JEEP GC SRT8
6.4L HEMI
FYI - my front sway bar is hu-normous, both in length and girth...so I most certainly would have noticed them rubbing it...my wife rubs it all the time. :party36:
But seriously my replicas have the following specs:
Bolt pattern = 5X139.7
77.8 mm center bore
25 mm offset
BrBlack
Calgary Alberta
I ask as SRT wheels are very common MODs around here. I hadn't heard that spacers were needed to properly run the SRT wheels.
Currently Im trying to switch to 22" SRT wheels.
I am running 22" x 10" SRT10 replicas with Yokahama Prada Spec X 305/45 R22...no spacers...never rubbed...ever.
I currently run 305-45-22 with out spacers and never thought the rubbing was an issue.
Just wanted to make sure I had all my facts before I pulled the trigger on a set of wheels.
