Spacers w a 5" lift?
tiger9297
Tupelo, MS
Cummins 5.9
I have a '99 2500. Running 17" aluminum wheels off of a 03-12 2500 and 37x12.5's. Also running a 5" lift. I'd like to have a little wider stance in the rear. Would there be an issue with running wheel spacers in the rear to add a little width?
dudeman2009
2001 1500 Sport with enough electrical modifications to make my brain hurt
Magnum 360
Not unless you haul a lot of stuff. If you keep the spacer at 2.5in or less you won't substantially affect the axle bearing life, above that and things start to wear faster.
Just be cautious of the spacer you order, a lot of the spacers for the Dodge hubs (at least on the 9.25 axles) require a special splined acorn nut in order to bolt the spacer to the hub and still be able to get the rim on the spacer.
It's not a major issue, just be aware of the hole size on the spacer that will slide over the factory hub studs.
Also, if you end up getting splined acorn style lug nuts, only get the 6 spline, 5 spline lug nuts are cheap and crappy.
dapepper9
Iowa/Nebraska Border
5.9L V8
Also make sure they're hubcentric. This is where the horror stories and bad information comes from about em. Guys don't buy hubcentric and get cheap ****, studs shear and wheel goes flying down the road, guys bash the spacers for their stupidity
