Spare Tire Fitment
Skrap
Orange County, CA
2015 Laramie MegaCab 4x4
I am going to get my tires rotated next weekend. When I bought my Cooper ST Maxx 295s I only og tfour of them. I have three long road trips coming up between now and Christmas and think it may be a good idea to get a proper spare or at least the same spare as what Im running now on my other four.
Will a 295 fit up under in the spare tire location? How tight? Tire is about 34.5" overall. What say you? Thanks
SportinaHemi
Arkansas
5.7L HEMI!
Pretty sure I read 35s won't fit below bed, which has me looking at possible bed mounted spare solutions... Not sure how tight it is, and I read that in passing. Hopefully someone can come in with a definitive answer.
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
I'm not sure if they will fit or not, but when I measured the stock 18" firestone my truck is wearing they were 34" so I would think they'd fit?
mohemipar
2017 Laramie
6.4 Hemi, 4.10's
I tired to fit my spare KO2 under there and it would not. Inflated mine is a bit over 34.5 inches. I was going to try to under inflate the tire a bit but never got around to it. I honestly don't think it would even matter.
Also, between the wheel I have it mounted on and the weight of the tire itself, the whole thing just seemed a bit too heavy and awkward for the system. This may be different for you. My tire weighs around 68 pounds and the wheel is I think about 35. It was a PITA trying to get it up there straight and then when I finally did it was too big. I forget what part it was hitting on first, but it was at least a good 1+ inch too big in diameter when I took a good look. Sucks.
I just keep mine ratchet strapped into the bed. If you need use of the entire bed, that's when you have a problem lol.
BTW, my spare and the normal factory tires on the truck only measured about 33 inches.
BiGMERF
2017 SLT 4x4
v6
am i the only one that rides around with the spare in the bed of the truck instead of underneath? lol
reloaderguy
Oregon
2016 Power Wagon
35" spares fit depending on the tire. If you can't fit a KO2 you need to try harder.
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
I could fit my 35 under the bed of my '98 RAM... I just had to under-inflate it, get it into position, pull it as far back as I could to clear the rear diff, then air it up most of the way. To remove it, I would just jam the bar of my Hi-Lift under it and pry it down. Mount it on the truck and air it up all the way. I have not upgraded the wheels/tires on my '12 RAM yet but I imagine I'll have to do the same thing.
