Spare wheel fitment
Stuffpower
Ok. So I’m buying 35s. Which from what I read fit the spare just fine. I also learned that the spare for some reason is an 18 inch wheel. A few questions.
what size with 18 inch wheel equals a 315/710/17.
if I go the other route and buy an oem rim, can anyone comment that it will fit in spare location.
the tire I’m going with are nitto g2s
Grand Mesa
295 70R18. Roughly the same diameter, but skinnier.
olyelr
Kewadin MI
The spare wheel on a power wagon is 17”.
Fatbob Frank
Mc Gregor, Iowa
6.4L
Mine was 17" too, but I haven't been able to shoehorn that 35" tire back up under there...
S
Stuffpower
Mine is a 2021 and I’m positive it’s an 18. The tire isn’t matching. It’s a street tread
Xyleff
California
2021 here with 17” matching duratracs.
Katy, TX
2021 here, 17" spare wheel for sure.
Go ahead and remove the heat shield all together before installing. I beat mine back and back and back...eventually got it to fit. When I get a 5th factory wheel and drop the spare back down, I am taking it off all together.
Adventurebound
Las Vegas
I know its off topic but my 35 fit fully deflated. Just be sure to carry a pump.
SeppW
Northern VA
Hemi 6.4L
You are referring to a Power Wagon? If you have a 18 inch wheel as a spare then someone goofed on the assembly line or the wheel and tire was removed and replaced with a different wheel by someone. You should have a standard 17 steel wheel as a spare, unless something has changed on wheel type.
Before you mount a tire on any rim that you plan to use as a Spare
Test fit the Center Bore, ( hole in the center of the rim ), with the apparatus that hangs at the end of spare tires cable
That mechanism may be to small to securely hold the rim in place
The steel rims that they use for spare tires, have a different size center bore than the Alloy Rims
The difference is not much, but it is best to be aware of it
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
The only scenario where you have both 1) a Power Wagon and 2) an 18” wheel with a street tire as a spare is if it was a factory error, or a previous owner replaced the spare for some reason. Wagons come with a 17” spare with a matching Goodyear Duratrac tire. No exceptions.
Brian2081
Weatland Michigan
Here is my 35 12.5 18 Falken MT on OEM rim under the truck without doing any type of mod.
Grand Mesa
The 35 12.50R17 Falken MT is slightly larger in diameter by 0.1" than the 18".
Uga998
